configure cfm segment frame-delay/frame-loss transmit interval
configure cfm segment segment_name {frame-delay | frame-loss} transmit-interval interval
Description
Configures the delay between two consecutive DMM/LMM frames.
Syntax Description
segment_name
Alphanumeric string identifying the segment name.
frame-delay
Y.1731 Ethernet frame delay measurement.
frame-loss
Y.1731 Ethernet frame loss measurement.
interval
Trasmit interval in seconds, with a range of 1 to 90.
Default
N/A.
Usage Guidelines
Configures the delay between two consecutive DMM/LMM frames. The configured delay would be for both continuous and on-demand transmission. This command is optional, and if not configured, the default interval would be 10 seconds.
If the optional keyword frame-delay or frame-loss is not specified, the same value of transmit-interval will be used for both DMM and LMM. The optional keyword allows configuring different values for DMM and LMM.
configure cfm segment cs2  frame-delay transmit-interval 10
configure cfm segment cs2  frame-loss  transmit-interval 10
This command was first available in ExtremeXOS 15.1.
Platform Availability
